"Emission workshop " light on
My wife has a 2005 Octavia Elegance 2.0 TDi PD Elegance. She is currently 100 miles from home, due back tomorrow. She has just phoned me to say that the "Emissions workshop" warning light has come on. Will she be ok driving it home?
What is the light warning of?
Thanks,
Mike.
Had it on mine as well, in my case it was a 20p fuel temp sensor.
I guess there are therefore many reasons for it, and the only real way to see the exact problem is a VCDS or dealer fault code scan. You dont have a DPF so it cannot be a problem with that.
I drove for a few weeks with it coming and going away, so I guess if its the sensor then you'll be fine.
if the car drives ok and no lack of power , then its ok to continue
"URGENT HELP"
My car a Octavia II 2006 1Z is displaying "Emission Workshop" sign on dash, i checked with VCDS it shows
1 Fault Found
000665 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Mileage: 40050 km
Time Indication: 0
Freeze Frame:
RPM: 2310 /min
Speed: 69.0 km/h
Load: 41.6 %
Voltage: 14.21 V
Bin. Bits: 00001000
Absolute Pres.: 1601.4 mbar
Absolute Pres.: 1122.0 mbar
Readiness: 1 1 0 0 0
my dealer has changed my EGR valve but the problem still persists
help guys
thanx
Manish
