vrs with slow turn over
bump
the car has been in again to the garage to have the seals changed on the fuel lines,but made no difference,went back again to have it air/fuel leaks and pressure tested along with all the other gadgets the garage had and still nothing.
the only thing the garage now suggested was to buy and fit a fuel non return valve plumbed into the fuel lines????
its annoying more that the car comes up fine on all the tests its had
anyone else suggest anything and would this vavle be ok?
cheers
simon
try a set of glow plugs. the way you keep having to switch the ignition on and off to make a difference does also point to a glow plug problem. esp in the cold weather. there not too expensive either.
http://cgi.ebay.co.uk/Skoda-Octavia-Fabia-VRS-1-9D-Set-of-4-Glow-Plugs_W0QQitemZ400093196318QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item5d2769b01e
Mine has started to do the same in the cold weather. Mine is also fine for the rest of the day after the cold start.
ste
Edited by stevei
thanks for the feedback m8 :thumbup:
the glow plugs have been tested and are fine
another update
the cars been in to have a 1 way valve fitted,the fuel line was clamped overnight then taken off in the morning and it started straight away,so they put the 1 way valve on that
thing is its still the bloody same grrrr.my bill is just over £200 now and the garage said they basically dont know what else to do
anyone help me please
  • 9 years later...
On 14/04/2010 at 19:09, toosmiles said:
another update
Did you ever get to the bottom of this issue and find a resolution, toosmiles?
This thread is ten years old, if you're having similar difficulties please start a new thread and give us as much detail as you can.
Ok will do. Same issues as described in OP, but will do some fault finding of my own so as to be as specific as possible for new post.  Thanks
