Octavia II 2.0 PD 140 fuel filter
Hi all
Where is the fuel filter on a PD140 located?
is in a big metal enclosure under the bonnet. As you stand in front of the car, you cant miss it, on your left just behind the headlights with loads of pipes coming out of the top.
Thanks for the prompt reply.
Yeah I know where it is now, thanks.
Is it easy to fit? How do you do it?
I dont know how to swap the filter, as I have always had the changes done at service time as per the service schedule.
I'd look the procedure up just in case, I've read it can be a swine. Need to make sure you fill the filter housing back up with derv or it will be a pig to start.
