skoda favorit lowering ?
i have just brought a set of springs lowering by 40mm and just wondering if anyone has done this and had anyproblems ?
cheers
I lowered my fav by 3 coils on each spring and had it running on 14s with 185/60s on. no problems then , but springs on front did wobble a bit when i jacked it up and took weight of them, so be carefull if you like to get airborn
i like to keep on the ground but i do take corners fast on my 15s 195 45s on then :)
i used -40 springs with 195/45.15's no problem
are felicia shocks shorter than the fav ones ? when i turn the steering the springs move round and make a very bad sound going round corners :S everythings been tightend down
No, they're identical front and rear - the only, tiny, difference is that the Felicia front ones have a little mounting point for an ABS sensor and Favorit ones (from some makers) don't.
