Clutch? 2002 Octavia VRS
Right,I'm a proud owner of a 2002 Octavia VRS.Out doin the shopping with the missus literally 2 hours ago.
Driving out of the car park,and came to a halt.
Went to put it back into the gear,It simply refused.
Car will go into gear when I turned off the ignition,I managed to get it into reverse and with the help of 2 lads got into a parking space.
What am I looking at?
Clutch?
has the pedal gone soft ? or gone to the floor
Pedal seems fine,I can engage reverse and use it.
Just no forward gears
There was a comment floating around here somewhere about someone who had a component (a pipe I think) fall in the engine bay and cause an obstruction with similar consequences.
I have a problem with going from 2nd to 1st gear unless the car is just about at a standstill. It is the only problem with gears i have and the garage say they will have to strip down the gear box and re-build it at a cost of 600 quid!:mad:
Does anyone know anthing else this could be as it on happens some times and only when doing about 5mph?:confused:
gear linkage?
Had a similar problem a few months back when I was unable to drive through injury for a couple of months.
father in law took it for a spin and whilst out lost all gears but managed to scrabble it into a drivable gear with engine off started with clutch in and straight off to garage they looked over it and sprayed so lubricant on linkage??? Not had a problem since
gear linkage?
I did the exact same thing this evening,got it into 2nd while off,turned her on and drove it the 3 miles home,(like a granny)
If thats the issue that doesnt sound too bad,fingers crossed :thumbup:
Fantastic news
The clutch needs to be replaced,along with the flywheel.
As you may not know I live in rip off ireland and parts are ridiculousy expensive here.
I need to source a clutch kit for my car,can anyone point me in the right direction?
Hi Cutt off. I'm in Mooncoin Near Waterford. I used live in Limerick!! Vrs owner here to. Story?
One sick octy!i think i know yourself from boards,
Garage has said that the car needs a new clutch and he recommends a new flywheel aswell,he can get the parts which will cost me 600 euro.
Im hoping I can source them cheaper from the UK
An upgrade sachs clutch and flywheel from Jabba is only 400 sterling!!
I'm afraid I'm never on boards. Try octane.ie for a look around. Or vagdrivers.net
Really?That cheap and with the favourable exchange rate right now
