indicators playing up
I have had the Octavia (55 plate) for approx 1 yr, now the indicators are playing up, there is an intermittant fault, when I push the indicator stork up ie to turn right some times the LH indicator flashes, reset stork and push stork up again problem goes away,
I think it could be the relay failing judging what I read earlier on indicators,
anyone else had this problem or should I replace the relay as a matter of course.
Dave
You could try spraying some electrical contact cleaner in at the base of the stalk first.
