Purpose of.....
Hi all,
Can someone please explain to me the prupose of snow foaming a car. Tried reserching it cant find any information. Looks good though:D
Basically a high build foam is intended to cling to the body of your car, when its applied it will dwell and the moisture content will hopefully transfer into the bonded on contaminents of the car, as these loosen with the moisture and the foam slides off your car it takes some (not all) of the dirt with it leaving you less chance of rubbing dirt around on your car during the wash process and scratching your paintwork.
Having good protection in the form of wax/sealant will stop the dirt bonding easily and make it easier to come off but this has the added effect of making the snowfoam slide off easily too.
^ Spot on. The more dirt you can remove before using a sponge or woollen mitt, the better.
sponge :eek: i thought they were satan himself lol
Paul Dalton uses one. It's very special though.
oh ok.... could you give more info on that :o and i maybe being a bit dim but who is that :confused:
You can't beat a good snow foaming :thumbup:
May I reccomend the PH neutral snow foam from Elite Care Car. Realy thick foam, removes dirt like crazy and smells realy nice :P
Paul Dolton uses a Satan to wash his car??
