Hi, this morning I gave a look at climatronic 19.2 setting. When pushing hard enough on high gears, oil temp raise to 95°C. Does it sound fine or is it time to fit an oil I/C? TIA,
No that is fine, the ideal temperature for oil is just over 100°, if you fit an oil cooler (without a thermostat) you will be doing more harm than good as the oil will struggle to reach optimum temperature.
Ouch, so I have another excuse to push harder!
Thank you,
19.2 shows engine temperature not OIL.
