Heater - Very efficient or faulty?
We have just got a new 1.4 TDi 80 (around 500 miles on the clock now) with just the normal Climatic air con and warm air comes through very quickly which is fine. The concern we have is that it's only cold with the dial turned fully anti clockwise. If you turn just one notch, just under 16, warm air starts to come through the screen and face vents. In fact it's just a bit too warm so we have to keep turning it to fully cold. Is this normal or is there a fault with it?
I do not have your car but when I press the button for the demist front windscreen this happens to me , do you have this aforementioned button?
No, we don't have this button.
Mine is exactly the same, soon as its turned past 16 degrees it blows warm air, but then it would as above 16 is warm:D
Sounds strange. I don't recall this happening on my friends fabia.
Think he just left it on fan speed 1 with the temp turned fairly far down and don't recall it blowing warm air out all the time.
But as said above... i guess 16c is warm and the cabin is probably a fair bit cooler than that so it is maybe working correctly and trying to get the temperature up.
Phil
  • 5 months later...
My 2 year old Fabia 2 is exactly the same - either totally cold or too hot with one click.
My previous car was an old shape Fabia 1.4 100PS, and this was also the same.
Mine too... its cold in the Czech Republic thats why :giggle:
My 10 year old Mk1 Fabia MPI is exactly the same , and always has been so i would assume this is normal.
Mine seems to be similar, but if I leave the settings alone the heat output varies day by day. At least I didn't freeze in the winter.
18708
Andy, that's completely normal on the Fabia model you have.
I have climatronic, if it goes from one extreme to the other, I can just put it in economy mode... No chilled air, just outside temp. Not sure if you get that feature, if you do, try that!
Hi guys, first of all thanks for the valuable information you're all willing to share. I'm writing you from south America since i've just bought a New Fabia 1.6 (not the facelifted version). I love it! but i have one question regarding the heater controls: Mine is the regular climatic one (the one that has 3 "wheels"); the thing is that when I switch the air flow towards the feet the air still comes from the side vents (the top, centre and low vents work fine). Actually no matter which direction I choose it always comes air from these vents. Is this normal?
If it's not, is it too hard to fix it?
Thanks for your replies!
Edited by Fipa
Hi Fipa, think this is normal mine does this as well. It could be to make sure that the side windows always have some airflow so they don't mist up?
Fipa...yes this is normal for your model. Mine is the same.
Thank you guys for your quick responses, but the vents i'm refering to are the ones that are almost next to the windows, On each side of the dash board there are two vents, a narrow one that's like a grill (I suppose is for the windows) and another one that you can manipulate the air flow (closest to the centre and they have a silver color border)
I'm refering to these ones (where can manipulate the air flow). These are the ones where the air always comes out no matter which direction i choose (feet, windscreen, front)... is, it normal?
Sorry for my english, but since this supermini is rare on my country (I don't understand why all people here prefer to buy a VW gol - brazilian ones - instead of the Skoda Fabia...) this is the only complete/ serious Forum I've found.
Thank you all!
Edited by Fipa
Fipa - welcome to this forum. Your english is fine. Better than many. I wouldn't have been have able to tell if's not your first language.
No, thank you for joining this forum.
Thanks for your welcome! :yes: , anyway, I'm still raising my question (sorry if it's a silly one):
" ... but the vents i'm refering to are the ones that are almost next to the windows, On each side of the dash board there are two vents, a narrow one that's like a grill (I suppose is for the windows) and another one that you can manipulate the air flow (closest to the centre and they have a silver color border)
I'm refering to these ones (where can manipulate the air flow). These are the ones where the air always comes out no matter which direction i choose (feet, windscreen, front)... is, it normal?"
Edited by Fipa
The heater temperature and direction control are acheived by moving flaps within the heater assembly. In the old days the flaps were attached to the control by stiff cables, so as you lengthened/shortened the cable, you got a corresponding movement of the flap. These days it is done electronically, as you operate the control the electronic control unit tells the flap motor how far to move the flap. The flap motors could be out of adjustment or faulty and can be checked through electronic diagnosis of the heater system.
just checked today and mine does the same
Thanks Fabia55, guess then it's normal on manual climatic systems. ;)
