Lazy PC
evening,
is my PC the laziest in the UK??
i turn my PC on and boots up fine...loads windows fine... connects to the net fine...now after doing all that has a nap for 5-10mins...no matter what i click on it just doesn't load..even if i click on restart or turn off it doesn't...then will load everything in the order i clicked and restart if i clicked that (learnt not to do that now i just wait) and for the rest of the time its on never plays up !
have run spy ware and anti virus checks all clean...
all service packs installed..even number 2....and totaly up to date !
ideas please anyone??
Joel
EDIT: whoops should have been posted in Drawing room ..my bad
I had a similar problem, on an older PC where the thing would work for 20 -30 minutes before slowing and sometimes crashing. It was traced to a faulty fan, which cause the thing to overheat, and I had to wait till it cooled down till it worked again before the whole cycle begun again! Don't know if it is similar as I'm no computer expert.
evening' date='
Joel
EDIT: whoops should have been posted in Drawing room ..my bad[/quote']
You're not running ZoneAlarm by any chance, are you? I've had ZoneAlarm do this to my laptop before I uninstalled it.
Do you keep ALL your temp files to a minimum.
Remove temp internet files, keep your recycle bin empty.
After that run a Defrag on your HDD, If you have never run 1 it will probably take a while to complete.
Steve
