Auto Windows ?
may sound stupid but does the fabia vRS have auto up/down windows ? they work manualy with the switch but not on auto if it has that function ? all other cars ive had after disconecting the battery you had to shut them hold switch down for 10 sec then same closeing so it could learn the travel then they would work fine but ive tryed that and still nothing any suggestions?
Only with the key in the lock!
For remote total closure you'll need a seperate controller.
Do a search for Alientech
no i mean when im sat in the car to open the windows i have to hold the window botton down should it not go down with just one touch looking at the manual they should i think but not sure if they need setting if that makes sense
Yes it should open both windows from the drivers side with one touch!
The manual should tell you how to reset one touch opening!
thats what its not doing any ideas?
hopefully no kittens died as i did do a search but that worked thankyou
Your welcome!
