felicia front indicator bulb replacement
Looking for help on replacing front indicator bulbs on 95 felicia 1.3 glxi. I just can not see how to get at them and would appreciate any help.
open the bonnet and there is plastic clip which you depress which allows the indicator light unit to slide out.
on the rhs you might have to remove the air filter housing to make it easier to get to.
tibsy
You don't need to remove them to do that, you can just disconnect the cable from the back of the bulb and then twist the plastic bulb holder to get it out.
Thanks Tibsy - just found that plastic clip. Problem solved. Thanks to all.
