Are these the right components I need to keep my CD changer and use an IPOD?
I've been doing a bit of research on this forum, but I just want to check that these are the right components I need for my head unit. My friend bought an ipod kit for his Octavia (same headunit), not sure which as I can't get hold of him, but he had to disconnect the cd changer completely. I know its not a massive deal to lose the ability to use the cd changer when you have an IPOD plugged in, but it would annoy me.
I'm not sure what the model/version my head unit is, it simply says SkodaAuto STREAM on it. I don't have Maxidot, or a multifunction steering wheel, or a bluetooth capability, either. Here are the parts that look like they will do the job, and be simple to retro fit.
Dension 100 (or 300, but I don't need the USB input so the 100 will do)
Dension Gateway 100 | Dension Gateway | Full iPod Integration
CD Changer/IPOD Splitter Switch thing...
Skoda CD Retention Kit | Dension ice>Link Plus iPod Car Kit | iPod Car Kit Direct
I don't want to get a cradle incase the missus leaves her ipod on display, so I will get a cable (does one comes with it?) to route into the glovebox or center box or whatever is best. Ah this is it.
http://www.ipodcarkitdirect.co.uk/Dension_Dock_Connector_Cable_for_iPod
The CAN (text) versions cannot be used with the CD Changer retention kit. As you don't have Maxidot I guess that doesn't matter to you, but make sure you don't buy the CAN version.
If you'd like any more information I am a Dension authorised supplier and can supply the items you require.
It was one of your threads I got most of the infromation from, so would gladly buy the parts from you if you can advise which I need as I'm concerned I might buy the wrong bits - like the whole CAN thing, nothing about that on that website.
