Adjust headlights
My normal headlights are too low, how can I adjust them to go up a little???
The roller inside the cabin is all the way down, so I need to adjust them inside the headlight chassis?
Should be on 0 that should be level and correct unlaiden.
If the roller is all the way down then the headlights will be low.
That is correct as per the manual!
Turn the roller all the way up and the headlights will go up.
  • 2 months later...
I meant the roller is at 0, so I cannot get the lights higher....
currently they are only lighting up the road 2-3 m ahead of me.....
it's only the left light that has problems....
someone must know how to do this please?
When you rotate the adjustment knob, do both headlights go down or does the one with the problem stay in place and not move. If it does not move then the mechanism inside the headlamp has broken and it may not be possible to adjust the light to the correct alignment using just the adjustment screw.
before you start adjusting the lights check that the left bulb is properly in place in the unit,
