.wav > mp3 conversion software
As the title suggests, can you recommend any software (preferably free) downloads for music file conversions.
TIA
erm i think you can do it in itunes
VLC Media Player: http://www.videolan.org/
How-to: (copied from here)
1. Open VLC.
2. On the Menu, choose File -> Open File.
3. In the File tab, browse for your file and select it. Check the Stream/Save check box then click Settings.
4. In the Outputs section, check the File check box, enter the target file name of your choosing and make sure it ends with .mp3 .
5. Choose Raw in the Encapsulation method section.
6. In the Transcoding option section, check the Audio codec check box, choose s16l from the dropdown menu then choose your preferred bitrate.
7. Press Ok twice and start the conversion.
Thanks!!!
Also try CDex :)
Also try CDex :)
Thanks!!
dbpoweramp does it for me :)
Thanks!!
...or a free convertor program that will handle virtually everything you can throw at it - audio and video.
Format Factory
http://www.formatoz.com/
