fuel filter
My skoda flairline n reg stutters,could it be thefuel filter.
:rofl:
When??? idling?? Accelerating, more info needed.
(Unless the speech therapist solved it :giggle:).
It does it when accelerating,noticed yesterday arcing from one of the distributor cap leads,maybe that is the cause???
Get it to a diagnostic machine, if simple they'll do it on the spot.-- Need more info about type fuel, engine size etc etc
Edited by giandougl
Yes, that will be the cause.
Thank you.
Thank you.
:) No problem, good luck with it. Please let us know how you get on. :thumbup:
Thank you.
As far as i know the sparking only happens during starting the engine,also now my battery light indicator comes on but just for a split second very faintly.
My alternator is not charging the battery,according to the AA man who brought me home is this a new one or can i change the brushes?
Depends, you can try changing the brushes but sometimes it's more severe than that.
Took the regulator off 1x brushes has dissapeard the other is worn down a lot ,bought a new reg with brushes all working ok now,thank you.
