Air con compressor 1.4Tdi
On earlier VAG vehicles I believe there was a problem with the pulley on the a/c compressor coming loose,or even coming off, as it is only held on by a nut, which resulted in the shaft becoming damaged needing a new compressor for a very large number of pound notes. Does this problem exist on the new type Fabia? Most other makers seem to rivet their compressor pulleys on I believe.
Chris
It's not a known problem on the Mk2 Fabia. It did happen a few times on the Mk1's.
