Disabling imobiliser
hello chaps,
does anyone know how to disable imobiliser from working on skoda octavia 1U model using VAG COM?
Do i need working key to disable this or it can be done with un metched key?
You can't disable the immobiliser with VCDS.
What engine is it for?
ok,
thanks for your intrest in helping me out,
I belive engine code is AGN, 1.8 20v naturally aspirated.
Bought this car, droped key on the floor and lost litlle transponder inside key cover, i have spare litlle transponders but as i dont have imobiliser pin code i am unable to mach key.
Any suggestions, apart from taking it to skoda dealer and let them to code key via GEKO?
Thank you
I could either kill the immobiliser for you, or retrieve the PIN for you so you can properly code a key, if you post me the ECU. Where are you located?
hello Sharky
I can code key myself as i have the VAG-COM hex+key just need a pin.
Im based in essex?
How much would you charge me to read P.I.N code for me?
Kind regards
