Keys reprogrammed by Dealer
I had to get my keys re-programmed as the main key stopped lowering and raising the windows of my car. Now the auto door lock is gone and the drivers door only opening is in operation. When I went into the MFD menu previously the Comfort / Convenience was there and I could turn adjust these no problem, but its gone now. I intend tom bring it back to the dealer to put it back to the way it was beforehand. Can this menu be adjusted via VCDS ? Does everyone with a RS Maxidot have Comfort / Convenience in their menu?
Last thing. Is it possible to use the VCDS to turn a needle sweep when you turn on the ignition like the FL RS?
A pure coincidence but I've just changed to auto-lock (anti-hijack) on my new vRS - do it through Maxi-dot using the convenience function in MFD - it's fairly straight forward but if you're struggling I can write down the actual process.
Hi Thanks for the reply. I had this on my maxi manu but since the dealers visit ithe convienence setting is gone :wonder:
Going to get on to them on Mon Morning!
