REAR SCREEN WASH FABIA VRS
Hi When I try the rear sreen wash no water comes out and all the water comes out below the water bottle above the front wheel.. When I try the front washers no problem..
Have I got a pipe off going to the back or a blockage somewhere. Is it easy to get to the water bottle from near the front wheel or do I have to go in through the engine compartment.
Any advise guys
From inside the engine bay behind the airbox you should see the pipe has come off. If you need to get someone to try the rear washer while your looking for the pipe. The ****ing out water should show you the way :)
