Yeti S, how many speakers there should be?
Hi
Did you manage to install speakers in the back door ? I want to do the same, any help appreciated!
A very old thread, so I doubt any of the original contributors will comment. However, the way I read this is that the wires being present (or not) is only part of the issue. Even if they are and you can get the door card/speaker cover off to fit a same size speaker in you still need to wire it into the head unit which isn't designed to run the extra speakers. You may be able to splice into the front speaker wires, but you would still have power issues as the base head unit only puts out 2 x 20W.
I suspect you will need to invest in a new 4 channel head unit as well as rear speakers.
Edited by Falmouthboy
