Advice on fault code 001537
Hi
Any info on fault code -001537 intermittent control module memory check sum error in terms of 'is this a remap' and 'has anyone had this done and how much did it cost' etc
Car is 06 Octavia Vrs 2.0fsi.
taken from http://wiki.ross-tech.com/index.php/Category:Fault_Codes
01537 - Vehicle Level Sensor; Supply Voltage
01537 - Vehicle Level Sensor Supply Voltage: Signal Outside Specifications
Possible Symptoms
-Malfunction Indicator Light (MIL) ON
-Possible Causes
-Fuse(s) faulty
-Wiring and/or Connector(s) from/to Headlight Leveling Control Module (J431) faulty
-Headlight Leveling Control Module (J431) faulty
Possible Solutions
-Check Fuse(s)
-Check Wiring and/or Connector(s) from/to Headlight Leveling Control Module (J431)
-Check/Replace Headlight Leveling Control Module (J431)
