You are doing it right! The big Skoda Octavia II picture thread!
What drop is that??? looks really well :thumbup:
Thanks mate. Around 55-60mm, ap's wound down to the bottom with helpers and rear adjusters left in. The spacers on the rear really help. Forge 16mm. Really nice quality too if you find a set.
  • Replies 3k
  • Views 912.5k
Yeah, I do like the hybrid pre-fl / fl front end look. Best of both worlds.
7F20079F-90F0-4E9C-A7FF-350C8BC9FE6E_zps
Love this looks really cool! Is there a write up on here on how to do this? Or is the member stil on here to have a chat with?
You have to heavily modify (includes plastic welding) the bumper below the headlights. Basically you can't use any of the Pre-FL bumper bits and on top of that you need newer CECM, some wiring and FL grille. If you really want to do that mod i suggest you do some recearch by yourself... No one gave me advices and i managed to do it myself. I've been given some advices to multiple people on this forum and no one of them have replied on the PM's... I think they have been frighten by the cost of the mod or the amount of work that is involved on it.
ow ok and u managed to do it on ur car? Did u do a write up on how to do this mod and what parts was needed to complete it? Have u any pics of ur car with it done plz
Everywhere? :)
They're neuspeed RSe07's, 18x8 ET45 and about 9kg each. I had them on mine until recently (post #1483 and #1488 on p50 of this thread). Now sold to Alex @ AKS (post #2187 on page 73). j0hn also has a set now.
HTH.
Yup neuspeed RSe 07. The offset is perfect. Flushed nicely with the wheel arc [emoji1]
Look on page 72 on this topic for example to find some pics.
Parts needed in a short list are:
The bumper itself, fog lights, DRL lights, connectors for the fog lights and also for the DRL´s, mounting plastic things that hold the DRL´s and headlight washers, covers for the headlight washers and the headlight washers ofcourse and finally all the grilles (5 pieces of them). On top of that you need the FL grille and bonnet extension plastic bit which attaches the underside of the FL grille to the bonnet.
Also as mentioned you need the newer CECM to make the DRL's to work properly. Allthough it is not necessary, as i did not change it but my cars lights (DRL's and headlights) don't function the same as the FL ones. I wired the DRL's to the fog lights (with some extra resistors to get rid of the fault codes) and coded the fog lights to work as DRL's with VCDS. Then i completely rebuild the wires, relays and switch for the foglights. Not OEM workaround but works for me and fulfills my country regulations.
I did all the modding and fitting myself and only the painting was done by a professional. The total cost for me when i did it was around 1000€ and the only part that i found second handed was the bumper shell...
Our 2009 Octy estate cleaned, polished and on the Eurotunnel.
post-118850-0-88769900-1406571686_thumb.jpgpost-118850-0-98596000-1406571690_thumb.jpgpost-118850-0-49330300-1406571732_thumb.jpgpost-118850-0-20602700-1406571734_thumb.jpg
Mine
Not had it long, but already colour coded the grill surround and changed the badges to new style smoked versions.
Other plans include coilovers and some 19s.
Edited by Dubbsley
theres mine
What is the paint code for this? Is in an exact match? I have a silver vrs and looking to do the same to mine
If u lift the boot carpet, there should be a sticker with those details, the same sticker should be on the inside of the service book.
What alloys are these been looking everywhere?
What he says \/
Also, not looking even remotely hard enough. Actually, you can't have looked at all :D
Everywhere?  :)
HTH.
I do indeed. These are what I wanted but I was put off by the ridiculous lead time and bought a set of TD PR1.2s, which kind of looked ok but never really suited the Mk2 in my opinion. I should have just bitten the bullet first time and bought the RSe's
Unfortunately I can't even be remotely bothered to take a proper picture at the moment, so here's one done with the phone when I went to buy some bog rolls or something poncey like asparagus (British obviously).
Untitled by jonnyguitar, on Flickr
Nope and I'm pretty sure Alex has never been a member on here. If you want to know more about his car, you'll find a fairly comprehensive write up on mk5gti forum although I don't know if he's written up the work involving fitting the FL bumper.
  • 4 weeks later...
Has anyone fitted Porsche twists in 18s or 19s to a Octy 2 VRS yet?
After a bit of DodoJuicing
I like the DoDo juice too :D
This is mine, only had it for just over a month. Was terribly neglected when I got it. Paint is pretty much the best it can be now for age & mileage
Sent from my iPad using Tapatalk HD
Added cupra r splitter today and new rear discs and pads
Love dodo juice now..was dubious at first and have tried purple haze pro and normal blue velvet. Hard wax is better imo but also used clay mitt from halfords with g3 detailer spray makes a HUGE difference!!
Polished with autoglym. Wanting better stuff to start detailing though
Been using autoglym for years, nothing wrong with it and always gives an excellent shine
Sent from my Nexus 5 using Tapatalk
How have you got the cupra R splitter to fit so nice? Everywhere iv looked they sit to far back and not wide enough?
Two pairs of hands a lot of swearing and a few holes lol.
Serious took the bumper off and did it with the bumper upside down. Didn't need to heat the either like someone else suggested.
Match the corners up first and self tapping screws then work into the middle. Couple of machine screws (the type which look like nuts and bolts in a green packet in b&q) thru 5.5mm holes. used 6 of these in total and then self tapping screws at regular points along the splitter.
Its sitting quite nicely couple of smallish gaps but nothing really visible, ill get a couple more pics.
Give me a shout if you want anymore info
Agreed, Autoglym is good stuff, especially the polish , deep glass clean and interior shampoo :D
I'm also liking the Autobrite range, cheery glaze is very good on dark cars.
Ash few more pics
Before anyone says it, yes I know the grass needs cutting!!
1B58D533-E017-4476-8F82-DAB7A11369D2_zps
What naughty alloys are they?
