Xenon bulb replacement
Evening all, SWMBO's Vrs has factory fitted xenon's but one bulb has faded quite a lot and is a creamy colour whilst the other is still blue/white. I dont really want to spend £100 on a bulb from the stealers so just wondered if anyone knew of any cheaper alternatives?? Thanks in advance :)
Edited by Gaz_vrs
ebay
HIDs direct
HiDs4u do them I think. MEant to be ok for customer service too.
http://www.hids4u.co.uk/hid-bulbs-c-2.html
Thanks for that, which ones does she need? Sorry for being a bit thick. :D
Edited by Gaz_vrs
www.powerbulbs.co.uk for me - It's a D2S IIRC.
Steve
Yup! D2S And best change both at once this keeps the colour balance the same!
Out of curiousity how old is the car?
A wee bit of searching should secure a pair for under £100. Try and get either Philips or Osram capsules.
Its on a 04 plate but has done 95k so i suppose thats not to bad really.
Yeh definatly go for Phillips or Osram new ones, try to not buy the cheapy ebay copies, they don't stay bright for very long (although they are cheap), they seem to loose power pretty quickly.
How easy are these to fit? I've seen how little room there is between each headlight and this has put me off somewhat...
Should take about 20mins a side if you take your time! Just remember you MUST disconnect your ballastsemoticon-0148-yes.gif
