climatronic
hi guys can anyone help my climatronic seeems to be acting up the problem is with the blower it blows but not very hard is this an easy problem to fix or is it new climate controler time is so is it easy to remove thanks
Collegue had a similar problem which was caused by a clogged pollen filter (although was not on a Skoda), so may be worth taking it out to check it and replace if necessary
hi guys can anyone help my climatronic seems to be acting up the problem is with the blower it blows but not very hard is this an easy problem to fix or is it new climate controller time is so is it easy to remove thanks
Check that you have not got a burnt out dropper resistor by manually changing the fan speed in ECON mode.
You may not get an increase at each displayed bar and you must allow time for the speed to settle too. With a cold car and cold engine, mine has 6 steps in fan speed, with no change between the last two bars on the display.
Pretty much as above, but if you use the fan speed up/down buttons the fan goes out of Auto mode without the CC selecting Econ.
On mine, it rarely uses anything other than speeds 2 or 3 in Auto, unless it's a very sunny day and the air con is doing overtime to get the cabin temp down, or I select demist mode!
hi guys thanks for reply although not sure i understand not really mechanicly minded if i want to check pollen filter how do you do that and where is it pics would be great and is it easy to check and change thanks in advance
