Hi all
Hi have a fabia VRS its a fantastic vehicle, I wouldnt get rid of it for anything else, but there it a slight issue with it at the mo, if i go to use the rear wash wipe with the water it then causes the 10amp fuse to blow making the front wipers not work also. The rear wash wipe will work very speradically a couple of times then not work for quite a few days, if you do not try to use the washer function then the fuse does not blow, using the water jets at the front is not a problem, has anybody else had this issue or do you know what it is. Many thanks for your help in this matter.
welcome to briskoda
