where do i plug in my vag-com?
i bought a obd-II cable from ebay this week to test a few things out. but i have no idea where it plugs in to the felicia or pickup???
have i got the right cable, it has 16 pins and is a d shape.
i have been looking under dash and under bonnet. do i need to remove panels?
many thanks.
sorry guys. just had another look and it was staring me in the face! just above accelator pedal!
Your face is in an unusual place then. ;)
nope, i'm just very short.
so whats happening with this obd stuff then. when i plug it in it keeps telling me car is not obd compliant? thats using vag-com.
I presume you have the drivers set-up and vag-com connected to the correct port? Do you have the ignition key in the on position when trying to run it? Also it may be better to use the second option, the auto scan thingy.
The other end goes in your lap top hth :yes:
"# Posts: 7777" :thumbup:
lol no the felicia is not OBD II compliant, it should work with the PROPER vagcom cable ok but wont work with an obd II cable
If it uses k-line (or whatever it's called) the ebay vag-con 409.1 shareware version cables should work I'd have thought?!
Mine works fine with a serial VAG-COM cable bought on eBay, but as Jim says, it's not OBD-II
The wonders of "standardisation" where the regulating body is a) clueless and B) weak.
yeah it uses a single K-line with kwp1280 protocol, version 3.11 is enough for a felicia, but as said above it isn't OBD2
yea i got this one
http://cgi.ebay.co.uk/USB-409-1-KKL-VAG-COM-OBD-2-II-VW-AUDI-SKODA-SEAT-Cable_W0QQitemZ190329451002QQcmdZViewItemQQptZUK_Diagnostic_Tools_Equipment?hash=item2c5084f1fa#ht_3943wt_991
i tried it with 409.1 and 311.2 when i click obd it says not compliant, when i click on individual scan like 01 - engine it times out.
i've tried lowering the baud rate in device properties.
if it is not obd compatible what is it i can read with this cable?
i'm going to try the cable on a vw T4 and see if cable works there.
thanks.
