Upgrading to Coilovers, whate else to upgrade?
Well i'm finally getting round to fitting my KW Varient 3...
So what i'm wondering is while i'm doing my coilovers what else should I be upgrading and to what (include part numbers if you can :) )
I'm thinking along the lines of Cupra top mounts and top mount bearings...
Also upgrading to a rather large turbo (even bigger then my VT5 ;))
Adrian
dont need to upgrade anything man, they will be fine as is.
you may want shorter droplinks if going as low as me although i dont recommend that low. mines has been raised slightly, coilovers are still all the way down with the helper springs put back in.
Top mounts and top bearings are adviseable... may as well whilst they are out! I will do mine when I get coilovers...
dont need shorter drop links with kw's id recommend fitting cupra lower arm bushes while you got everything apart.
I plan on a very nice set of bbs rims something a bit wild for the fabia so I want a good stance but not too low I want have I handle good so I can still drive the car fast y0! Lol
And judging by your fbook comments...there's a nice arrival waiting on you too :D
You do need them if you are going super low or the drivesaft rubs on anti roll bar.............
