Code 17554
I've done a search on the forum for this code but can't find any explanation for what the fault is and a likely cause. Can anyone help.
17554 P1146 Mass or Volume Air Flow Circ Supply Malfunction
I know that from the search but what does that mean in the i need to replace meaning
I would start with the mass air flow sensor and check for intake air leaks.
The code relates to the supply voltage to the MAF. It's either too high or low. Also could be the wiring. Source Autodata Diag Trouble Codes Book
Steve
