Boot floor size?
Would somebody be kind enough to measure the width of the boot between the wheel arches and the depth (from the back of the seats to the rear of the car) Thank you. :)
Hi,
across is 1m
depth is almost 74cm from the fixed centre seat; note this figure is taken from the raised floor of the spare wheel option. Although with the slight curve of the rear sill and a raised edge at the front of the spare wheel cover then 70cm is more realistic
Regards,
TP
Thanks TP, much appreciated. :thumbup:
TP you're a star!
:clap: :angel: :sun:
Hi,
across is 1m
Regards,
TP
Thanks TP, you've just saved me a job.
I need to get a dog cage and wanted to know if the one I'm looking at will fit (it will).
So it's the same width as my Octavia, but shorter front to back. Could I ask how far the outer rear seats slide forward please as I will probably need to do this to get my holiday suit cases in. (Unless perhaps I stand them up behind the rear seats :wonder: )
Many thanks for your help.
Chris
Chris
Hi Chris,
hope these are what you need, anything else just let me know.
front seat set for me at six foot, rear chair fully forward.
This final one is the shortest measurement I can find from the front up-stand of the spare wheel cover to the rear sill at the side.
Regards,
TP
Many thanks, they're just what I needed!!
Chris
TP....is that last measurement with the back seat pushed fully forwards. Hope I am not being silly, it is that I have a large plastic moulded dog box and it is 86 cms deep. Also I need 69cms height. Thank you in advance.
Hi,
that last measurement of 66cm is taken from the spare wheel cover up-stand as below
Note outer seat in rear position in this photo.
Shortest distance with the seat forward is
height wise
Add about 17cm to the above without the spare option.
Regards,
TP
Your a star TP. Thank you muchly. :smirk:
