FABIA VRS EGR CLEAN INSTRUCTIONS
DOES ANYONE OUT THERE HAVE ANY INSTRUCTIONS ON HOW TO REMOVE AND CLEAN EGR VALVE ON FABIA VRS. THERE IS NOT MUCH IN THE HAYNES MANUALS ON THIS? ALSO ARE THERE ANY GASKETS TO PURCHASE ETC ?
  • 1 year later...
Old post but I am also looking for a guide to do this on my vRS. Did you find one in the end.
There are quite a few topics on this, try the search. I did this a few weeks ago, doesnt take long but to give it all a proper clean the manifold needs to come off, or be careful that bits dont fall inside it.
Hi
I did try the search thats how I found this old thread. I was just wondering if anyone has done a complete guide with pics etc, like the one that shows you how to cure the leaking back window problem. There are a few threads on the subject but nothing that covers everything and the one with most info isnt for a vRS.
Maybe I will give it a go and do a guide for others.
One thing you might be able to answer is, do I need new gaskets or anything or is it just a case of remove clean and put back together with old gaskets.
Thanks again
Method varies depending on if it's an ASZ or BLT engine. ASZ has combined ASV and EGR, BLT has separate EGR and what looks like a throttle body. If unplugged it will throw a fault code and need reset after cleaning. Always use new gaskets and o rings when possible. As for cleaning, several large cans of carb cleaner and plastic spatula to scrape off the thick stuff, then tooth brush to clean off the rest. Also worth doing the inlet manifold. Dunk it in carb cleaner over-night (make sure no pets or people will be exposed to the fumes) and then clean inside with rotary brush on a flexi drill extension like you find in a Dremel kit.
  • 1 year later...
I am considering doing this in the next week or two - did anyone ever do a guide as I (like many) would feel more comfortable doing this with pics...
i'm going to be doing mine's (BLT engine) and my girlfriend's (ASZ engine) over Xmas
Do I see a "how to guide with pics" coming?? :think: :thumbup:
Congratulations, you have nominated yourself to make a massively detailled guide for numptys like me :)
When youve done yours kev, pop threw to Edinburgh and do mine, will provide beers...
Pics would be good... Video specific to the Fabia would be even better! :rofl:
There are actually some good instructions on here but I know what it's like... I always feel more comfortable when I can see what to do.
Pics and a guide arnt really needed!
Its a really easy job on the blt engine anyway. 30 minutes is generous just for removal.
i'll do a guide and pop it on if there's a demand for it
The ASZ engine is from an Ibiza though.
i deffo need a guide! got what i thought was all the bolts of my egr valve! I have a blt engine. and then it wouldnt budge! :S need help im a numpty
Some information on when the best time to do it would be ideal, e.g. every x miles, every service or after x miles, etc.
