"normal" MAF reading
Does anyone know what the normal "idle" reading should be from the MAF on a 110TDi? On the labels showing on vag-com, most of mine fall within the the range, but my MAF has always been miles off. I am working at home today, so I'll pop down to the car in a bit and get some readings and post them on there.
I changed my MAF a good few years ago, and certainly don't have the normal general dog like performance when th MAF has failed big time. Still I am wondering if mine is just on the edge.... Some days the car pulls like a rocket (rare), and sometimes it is really limp (normally after an overboost). Generally it does not feel as perky as I think it should. I would expect either perky or limp-home mode.....
Matt
What is WOT?
I grabbed a few figures before I saw your post, so maybe irrelevant, but here they are (fortuantely taken from group 003)
Test 1 (engine off)
Engine speed: 0 rpm
MAF (specified): 850.0 mg/R
MAF (actual): 1275.0 mg/R
EGR duty cycle: 4.8%
Test 2 (engine running)
Engine speed: 882 rpm
MAF (specified): 305.0 mg/R
MAF (actual): 325.0 mg/R
EGR duty cycle: 64.9%
Test 3 (engine running)
Engine speed: 2898 rpm
MAF (specified): 390.0 mg/R
MAF (actual): 395.0 mg/R
EGR duty cycle: 54.2%
It would appear from that (with no load on the engine, sat in the garage) that my specified and actual values are not far apart, and I can probably ignore the MAF from any future investigations?
What is WOT?
WOT = Wide Open Throttle
= flat out....
(feel sorry for any vehicles behind me :giggle:)
= flat out....
You will notice that the EGR duty cycle drops to its minimum value at WOT. IIRC this is 4.8%.
You should see a series a plateau between 800 and 850 for each gear.
Remember...
"Air through MAF" = " 'air' entering the engine" - "crap through EGR"
I would check the EGR to see if it is sticking.
Edited by rwbaldwin
I'll try and get someone to come out in the car and control the laptop for me and log some stuff.
Remember...
Had the EGR assembly off the other weekend and gave it a good clean up (http://www.matthewames.co.uk/briskoda/index.php?loc=./20100314_egr_cleaning)
