any1 know how to fit a FORDGE SPLITTER DV/BOV ?
IN DESPRATE NEED OF INSTRUCTIONS TO FITTING A FORDGE SPLITTER VALVE ON A 2003 OCTAVIA 1.8T
The search function does ;)
Try searching for diverter valve as that will give you most of what you need.
welcome to briskoda
welcome to briskoda
http://www.forgemotorsport.co.uk/media/USASPLTR.pdf
Idiots guide just there
It is easy , but set it up right
When fitted make sure adjusted all the way to the left
When engine is fully cold , start the car and leave to tick over
Turn the top to the right until the ticking stops and the engine is up to normal running temp
Then turn 2 more clicks , and there you go set up :D
Have fun
Sarah
brilliant,il let you all know how i get on.k&n induction kit might be the next question when the fordge is all squared away,wish me luck :( ;)
Good luck :D
Sarah
