High level brake light on a combi
Some of the leds have gone out on high level brake light on my combi, has anyone had take one of these out....aaannnnddd how do you take it out :wonder:
Word of advice: When re-mounting it do not make the error to tighten the screws too hard because then you get water ingress at the light, causing water dripping onto the boot cover.
As for the how-to: You have to remove the inner cover of the boot door, as seen here, after that remove the inner frame of the rear window which takes you to the screws holding the brakelight.
HTH
