Lights type
Hi, i would to change my rear licence plate lights, and was woundering what size they are on the fabia mk2.
it says c5w on the surround but dunno exactly size/length i need. cheers.
i'm not sure if its legal to change colour so what you're going to change, brighter?
Aye, jst bright white LEDs, got white LEDs or sidelights thnk they slightly improve look of car Especialy when they cheap to change.
i think i'd rather spend that on a nice steak
thanks for tht massively useful contrubution lol,
but also if any1 kows how to get to the main interior lights and what size/type they are as well thnx.
You get that alot around here ive found dude . pfft :dull:
Should have all bulbs and how to replace guides in the manual I think mate,
Also if you look on a certain lighting car specialist site, if you pop in your reg it will come up with all the bulbs for the car. Sorry cant rember which site it was. google is probs your friend here!
Edited by TorqueXIsXCheap
  • 2 years later...
Fabia 2010. has C5W license plate lights but they come in different sizes. Does anyone know is it 41mm, 40mm, 39mm or 36mm lenght of the bulb? Want to put on leds from dx.com.
From 39mm to 42mm you will be fine as the contacts are easy to bend. BUT I would like to caution you that they should be canbus error free because on the newer Fabias they cheaper kind of leds give an error on the dash.
I changed DRLs to common LEDs and no dash light flashing. Also put LED parking lights with no problem. Dunno... Thanks for the info.
w5w in the small ones in the cabin, 39 mm in the big ones and in the back.
w5w in the trunk and w5w in the glovecompartment!
  • 11 months later...
Does anyone know if there is OBC error on the dash if the fog light goes of? The car is Fabia Mk.2 Facelift, 11/2010. I know that there is no error if the DRL bulb goes of, and now I want to put LEDs in foglights, so why to pay more for error free if I do not need error free. Now it is -12 degrees in my country so I cannot go to the car and remove the bulb to see :D
I had error when drl Light Had Got water into connection and started flashing then when it broke and went out got nothing. More then likely was just affecting voltages for little while
Well yours is vRS. It should be different. Mine definitely does not put on OBC error when DRL bulb is detached and also yesterday I checked for the fog lights. All the same, H8 bulb removed, foglights on, no error. So you do not need CANBUS LED bulbs for fog lights in Fabia 2010-.
I'm gonna stick some of the 50w Cree's (£34/pair) in my DRLs soon, and I've already popped some cheapo 5xSMD LED's in place of my Sides (not sure if I'm happy with them just yet as the car came with Osram Blue w5w bulbs!) but I'm looking at a set of H7 replacement's for my Headlights (2 sets as I have 4 of the blighters!!)
My choices at the moment are:
Osram Nightbreraker Unlimited @£18/pair
or
Osram Cool Blue Intense @£12/pair
Then it's just the Fogs and Indicators, I dunno weather to go Cree/LED (£28/pair) for the Fogs or Osram Cool Blue H11's (£22/pair)!?!?... and then I dunno weather to go Osram Diadem Silvers or Diadem Blue for the Indicators both £10/pair...
This lighting milarky is such a confusing minefield!!!  :@
Nope! Took the w5w SMD LED's out... They looked Crap! Far too Purple! put the Osram Blue bulbs back, now they are White (not Yellow like normal w5w's) again!  :happy:
Now just have to save some pennies for this Shopping List:
Osram Nightbreraker Unlimited @£16.50/pair = £33
50w Cree DRL's = £34
H8/11 Cree Fogs = £28
Osram Diadem Indicators = £10
So £105  :sweat:  :no:  :S  :wait:  :yes:
I have 80w CREE in my DRL and 30w CREE in the fogs. Not happy with the light output of fogs.
I've got h7 6000k HID and 5w CREE side lights.
Led in rear numberplate and 10w DRL in reverse light plus silvertech indicators
Sent from my GT-N7105 using Tapatalk
