Felicia 1.3 1998
Have had a problem with the electrics. Fault was traced to the voltage regulator on the alternator, which has been replaced and now getting 14.25 volts. Before this was sorted I noticed that when returning to the car I found that there was a noise coming from under the bonnet. Further investigation, I found a small motor running under the air box and seems to be part of the carb. I thought the problems were connected, but now the voltage regulator is replaced. The motor on the carb is running when the ignition is off every so often. When you start the engine after finding this little motor running, the car seems a little bit flat on power when pulling away as if starved of fuel, but seems to clear after a while. I try to do my own maintenance but any pointers will be gratefully accepted.
that will be the idle stepper motor playing funnies by the sounds of it
is it a spi or mpi model?
Have checked again and it has mpi according to the owners manual. The model is 135 LX . Eng output 40kW.
Edited by DISC BRAKES
anyone got any ideas.
Well, it's not a carb, that's the throttle body for the injection system, and it has a motor in there to adjust the tickover.
It should not be powered when the engine is turned off, so there's something wrong - I thought all the power to the TB was turned off when the engine was killed, but I've not actually -checked- this so it could be that there is still power there (I see no reason why).
Can you try disconnecting the multi-plug that connects to the throttle body and see if that does stop it? It's fairly easy to reach, although you need to pull the retaining tab back to actually unplug it (a bit awkward).
The motor running on its own is intermittent, but on starting the car the engine it is a bit slow on pulling away like there is either to much or to little fuel and after a few seconds it seems to clear itself.
There is a problem that is causing the battery to discharge slowly. I have used a multi meter to show that there is a drain of .005 amp drain on the battery all the time, I have traced it to the first fuse on the left (1 amp) but am waiting for a Haynes manual to be delivered, so I don't know what that serves. I have checked for any other amp reading for a couple of hours with the meter in series and the only readings I noted was a .001 amp about every 30 seconds.
Still waiting for the Haynes Manual so still don't know what the first fuse on the left in the fuse box feeds.
I have a new problem that appeared today, I have been pulling the fuse mentioned above when not using the car to stop the battery drain. When I reinstalled the fuse and started the car, I noticed that the fuel gauge was not working and also the parking light, alternator light, etc were not illuminated on the dash board. Have checked all the fuses and found that none are blown, the other lights on the dash seem to be working.
Does any one think these problems may be connected or perhaps I have an unknown factor that I am not aware of.
I do hope some one can come up with an idea, they will definitely be better than my head scratching mode at the moment.
Well, that drain isn't significant - my Focus has a drain of about 80mA (yours is 5mA), and it's not a problem. Would probably be the clock. If your car has an 063 battery (I think the Fel should do) then it's 44AH. Which would mean at the drain that you say (5mA), it would last about 8800 hours - about a year.
Have you tried pulling the plug from the throttle body as I suggested just to be 100% sure that the problem is there?
fuse number 1 is for the ecu and some of the engine electrics fyi
I have disconnected the plug from the throttle body like you said but the motor isn't running all the time now. The engine seems a little bit uneven on revs though and has stalled a few times at lights and junctions and the like.
Thanks for the info on fuse 1, I checked it again today and now it is reading zero, but the car still doesn't feel quite right even though I can't put my finger on it.
If there is a fault on the throttle dody unit is the only way to prove it by connecting up the ECU to a computer? If the fault is intermittent would the fault be recorded? Not sure if it makes any difference but the throttle body is a Pierburg and the ECU is Siemens. Ta
yes on the seimens simos units intermittent faults will be stored in memmory even if you disconnect the battery, but they will be erased after the car has been started 50 times if the fault does not re-occur.
i think your best bet is to stick a new throttle body on there from a breakers yard, that is the most likely part to be faulty, it is highly unlikely to be an ecu fault but it does happen occasionally.
I will give that a go and ring a few breakers to find one.
I think I remember on one of the pages in the forum that if you fit a different throttle valve body you have to reset something on the ECU or may be it was if you fit a new body.
Or maybe its my brain that needs resetting.
Thanks again
you are quite right, you do have to reset the learned values, but if the replacement throttle body is functioning 100% correctly it will automatically re-learn it's settings itself, but it will idle a bit strange and may be a bit jerky for a short while :thumbup:
I have decided after today my brain does need resetting. Let me explain, I spent some of the morning climbing over cars in breakers yards looking for the throttle body, gone, smashed or just wrong type. On returning to the car, I found the motor noise happening again, the one that I thought was on the throttle body, well I have now traced the noise to the fuel pump. I proved this by pulling fuse 4 which I think, only feeds the fuel pump and injectors and the pump noise stopped.
I have checked the fuel pump relay to see that it is open circuit when removed from the fuse box and it is. I then stripped down the fuse box to look for a possible short, that could be causing a possible back feed.
I was thinking back feed, because according to the wiring diag in the Haynes manual the feed for the coil in the fuel pump relay comes straight from the ignition switch.
Pulling fuse 1 or 4 stops the pump running. Fuse 4 I understand in that it feeds the pump and the injectors.
What I don't get, is how pulling Fuse 1 which feeds the ECU stops the pump running.
My only excuse for the confusion with the motors is that I don't think i have ever heard a fuel pump running when the engine isn't running.
Also, on the way back home the engine died when I was driving along at about 30mph. I hasn't done that before.
I haven't got a manual here, but isn't the relay for the injectors and fuel pump controlled by the ECU? That would explain why fuse 1 would stop it, if so.
The other symptoms you describe (cutting out, etc) could be caused by a lack of fuel pressure, which would in turn be caused by a dodgy pump, amongst other things.
Let me explain my reasoning on the fuses and please tell me where my theory falls down because car mechanic I ain't. The fuel pump relay coil is powered by a feed from the ignition switch and the switch side of the pump relay has a permanent live feed from the battery. Therefore I assume that the pump relay is operating correctly because pulling fuse 1 stops the pump running by breaking the circuit to the pump relay coil. But how is there power to the pump relay coil when the ignition isn't on? Would the car carry on running if there was still a live feed from the ignition switch?
Basically, I don't know which end to start attacking the problem from because it doesn't seem to make sense how the pump is running on its own.
I'll have a look at the wiring diagram later, but I think you'll find that the Fuel Pump relay is powered from the ECU, -not- directly from the Ignition switch.
I have been trying to trace the fault and this is what I have found so far.
There is 12.7v from the ECU to the AA/9 connector on the fuse box and then to the pump relay base, when the pump relay is plugged in the volts drops to 5.37 - 5.55volts .
With the pump relay not in place I pulled fuse 1 and measured the voltage on AA/9 and it dropped from 12.7 volts to 0.60 and this dropping on digit about every 8 seconds.
I have got my hands on a VAG305 today which shows two faults:
00537 Oxygen Sensor Control
00525 02 sensor - Voltage Low -G39
Does that mean the 02 sensor needs replacing? Is there any chance of a connection between the faulty pump and the sensor reading? Thanks
it sounds like water ingress in the fuse box to me mate, it causes lots of problems like that if you h=are handy with a screwdriver you can remove the fuse box and seperate the layers to clean up the corrosion inside..
the lambda sensor also takes a power feed from the fuelpump relay which explains the fault code.
also i am fairly certain that the ECU actually switches the fuel pump relay via the - side, easy solution is a second hand fuse box if you dont want to strip yours
jim
No, I have stripped the fuse box down because I thought it might be down to water causing a short but it was as dry as a bone and the copper was as shiny as new. I did find it hard to believe with the several duck ponds I've had in the passenger well over the years, but that is another story. Thanks
the fuel pump relay is activate by the engine ecu.. it earths the relay on the negative side like jimbo says above^^ which creates a complete circuit in the primary side of the relay...
it is fairly common for water ingress from a leaky windscreen/sunroof to cause it to do funny things like this, might also be down to a dodgy fuel pump relay playing funnies
I have suffered in the past with water leaks from the windscreen and therefore thought the same about water getting into the fuse box or possibly the pump relay itself. I have stripped the fuse box down and found it bone dry and no signs of corrosion, the relay I have taken apart and checked its mechanical operation and powered up the coil to check its operation electrically. They can still be a bit suss though, so I have been looking for a replacement, but I didn't like the dealer price of 24.68. I have rung jorily but not heard back yet. Any one know of any other sources? The ones on ebay are not specific for skoda, but all seem to be VW pump relay, are they the same?
I get what you say about the ECU earthing the relay on the negative side of the coil, which creates a complete circuit in the primary side of the relay. The problem I have is that I am getting 12.7 volts on the negative side which is from the ECU, and the primary side is acting as a negative, because the relay is operating. When the ignition is switched on something changes though in the ECU, because the 12 volts on the negative side drops and when the primary side is powered to 12 volts, the negative acts as a negative because the relay switches ok. This of course is if the Haynes wiring diag is correct. Mine shows the neg from ecu to AA/9 to 86 on the relay base and the normal primary side of the coil to 85 then to AA/10 then to the ignition switch. I can't find a schematic of the ECU to try and work how this could possibly be occurring, any one seen one anywhere? Would vag com show what is happening in the ECU?
Thanks.
where are you? is there any evidance of an alarm or anything been fitted to it. i have at least 5 cars here for breaking so could find you a relay etc for beer tokens :giggle: or if you can get to me i will happily spend a bit of time sorting it.
it may be an ecu fault.
also check the loom connectors in the engine bay next to the battery for corrosion
