Engine management errors
Hello all,
Does anyone out there have knoledge of the codes and meanings for errors on a Fabia VRS SE.
I need to make sure that the errors that have come up with the Engine management light are those associated to the fact that EGR is missing.
I have replaced the EGR with an Allard straight through pipe. obviously on the BLT engine the EGR is in 2 parts and consists of a motorised paddle valve and a vacuum operated shut off valve to the exhaust system. Along with this change I also removed the breather pipe from the top of the engine and have a catch can installed now. Obviously the 2 of these will interupt the airflow readings in the MAS and just need to know if these codes are all to do with that or something else.
Any help would be appreciated. codes are as follows.
4569
4625
4C65
4C66
for some reason the codes I first had related to the cyclinders 1 and 3, but that made no sense at all. I cleared all the codes and then re-started engine and these are the codes that re-appeared.
Help wanted. thanks...
I don't know what equipment was used to retrieve those codes, but they make no sense. Fault codes should be in the following format
Example: 16514 P0130
