clutch price and recommendations
hello guys
the clutch is clonking when im changing gear , its always had a high point and 20k later its getting to its end i think,
had two prices so far ,
£540 with a single mass change?
£650 with a standard dual mass flywheel
£459 with new clutch on original flywheel
is it wortth changing the flywheel for an extra few quid? why is a single mass cheaper but veiwed as an upgrade?
Because the dual mass flywheel is fscking expensive for what it is.
If you "upgrade" by changing to a single mass flywheel then the next time the clutch fails you don't necessarily have to have a new flywheel as well like you would do if you stuck with a DMF.
Edited by chicken_eyebrow
