Advice please
Going to be doing the Elephant hose mod soon and Im going to cleaning the boost pipes, intercooler and intake manifold.
Are there any guides to removing these and anyone have any advice.
Also are there any bits Id need to buy like clips?
Thanks Stephen
fairly straightforward if you have mechanical competance...pull securing clips and remove intercooler hoses...flush intercooler with petrol.....inlet manifold has to be removed and crud scraped out...remove egr vacuum hose and block it....block the crankcase pipe to the inlet side of turbo and connect 20mm heater hose to the crankcase vent and run it to back of engine and cable tie it so it vents under the car....
jobs a good un... :yes:
Edited by warwick hunt
