What Size brakes
Looking round for Brake discs etc for the Silver Slingshot and i keep getting told i have a choice of 2 sizes
280mm front discs or 288mm front discs.
Does anyone know the correct sizes for a 2008 Estate (apart from me whipping a wheel off to measure)
Hmmm, I was under the impression it was 312mm vented on the front and 288mm vented on the rear - Euro Car Parts appears to back this up..........???
I think it depends on which caliper you have as to which size.
Can you post a pic of the caliper?
FS III callipers = 280mm (you will see FS III clearly stamped in the calliper)
ATE callipers = 288mm
vRS has ATE callipers and 312mm brake discs.
HTH
Edited by cheezemonkhai
FS III calipers = 280mm
ATE calipers = 288mm
vRS has ATE calipers and 312mm brake discs.
HTH
Assuming it's not your vRS what engine/trim level is it?
I found it thanks folks
For 2008 2.0 TDI PD140 DSG L&K models ( apparently the L&K have different brakes again )
288mm x 25mm front vented discs
260mm x 12mm rear solid discs
Cheers for the replies :thumbup:
L&K has the same callipers as the vRS at the front, so with the right carriers and a set of 312mm discs, you can use the existing pads and callipers to run the new set up. :)
