abs,traction control, handbrake warning all on !
i was driving to work on the motorway in my fabia 1.9tdipd when the abs light ,the small warning triangle light and the handbrake waring light all came on and started bleeping. i pulled into the services turned off the ignition left it a few min's then turned it back on and they wernt there. i drove the 10 miles further to work and no more warning light's , what do you think happened ??????h :S (they have never came on before or since)
have you had your brake pads/discs or fluid changed recently?
it is worth checking for fault codes with vag com also.
i had the rear pads and disks done about 6 weeks ago and had no problems, but last night in the way home i heard a creak , like a rear spring had broke or somthing . the thing is i do about 500 miles a week to commute so it is heavly used.
