Who's fitted 312 brakes before!?
Just got my old brakes off, it seems the bolt setup to attache the caliper to the carrier is slightly different?
IE, the old bolt is too short to fit to the new TT brakes to fit them together?
Any help appreciated please please please!?
Chris.
They're fine to use the original line and bolt..
It's just the new caliper doesn't have the retaining pin.
Kev
I'm uploading a video to show what I mean, i'm still a little confused
Any ideas!?
Edit, me being silly.
Still have the bolt problem though :S
Edited by CJS-90
Also what happens with the, what looks like, ABS socket on one of the pads!?
Thats a brake wear indicator, i just chopped it off!!!!
Edit i think, if you have something on the new 312mm pad its the brake wear indicator, your fabia doesn't have this function, if its anything else don't chop it off!!!!!!
Edited by oilburninnut
Are you using the fabia carrier? If so that is your problem, you need the tt carrier
Okay, i'll chop that off. Anything related to the length of the bolt situation!?
Only my carrier question!!!!!!
Nope, i'm using the TT carrier. The TT caliper/carrier seems to be too big, for the standard Fabia bolt, in that, it's not long enough to fit through!?
Not seen that before, unless you have mistakenly picked up a caliper to carrier bolt instead of a carrier to hub bolt!!!!!
From the video:
You don'[t use those bolts again. As the 312 is a different configuration, they're like a slider pin with a Allen key head..
Thats your problem
Kev
Okay, thanks, so where can I get these from!? Can I just get them from Audi!? Do I need all 4 as well!?
From the video:
Thats your problem
Kev
Theres a video?
You will need 4, you can get them from Audi, 2 seconds and i'll get you a Part Number..
Kev
Guide Pin : 251 615 219
Oops That will teach me to read the whole thread!!!!!! :rofl:
Im sure if you'd seen the video gary you'd have been able to answer it straight away :)
Kev
Thanks a lot!!
Haha :rofl:
Kev
Again, thanks a lot Kev!!
Kev
Lol i don't know its been a while since i had anything to do with a fabia :D
10.31 each plus vat! Jeeez
Not cheap, i only had 3 when i did mine but luckily there was one laying around in our spares..
Kev
Thanks for the thread/heads up..
wtf... and I possibly need 4 of them??
Google says it looks like this:
Surely that does not cost £12....
Edited by JLneonhug
