ABS & TCS Lights
My fabia vrs is showing its ABS and TCS warning lights ive done a search on here, i've looked at all the reply check the fuse on the battery but nothing is ever that easy to fix. can any one help me on what i should do next so i dont have to go to the dealers and have my pants pulled down, thanks Ben
It would be one of the ABS Sensors but vagcom or a diagnostics should confirm this...
Do the obvious checks:
Check brake fuid top up if necessary
Brake pads run down maybe time to replace the pads and discs if they are worn out not sure if the vrs has brake pad sensors
Tyre pressures low? could be causing a fault with traction control
Keep us posted.. Thanks
Thanks. looks like its going to be a sensor. new discs and pads fitted last months. I'll let you know what the out come is.
Thanks Ben
