Air Con
Hi To all
Only been on here once before. I have a Fabia 1.4 Estate (16v) 2001 (Y) I recently had a gas recharge because the air was not as cold as it should be. Now it only works when the outside temp is cold, when the outside temp is warm or hot the fan just does not come on or the air con does not get cold. Has anyone any ideas. By working when the outside temp is cold, I would think that the condensor and compresser work as the air con pipes get cold. Please any advice at wits end not even a couple of people that deal with air con know.
Many thanks
zampa :'(
Hi To all
Many thanks
zampa :'(
You need to get it to a Air-con specialist to check for leaks, its no use just keep topping it up, there could be a few places it can leak
Radiotwo
Hello and welcome to the forum, as said, get an air con specialist to leak test it :hi:
