Catalytic Converter snapped - how much !
My 2002 Octavia I has just failed its MOT. The tester showed me, the rear of the cat where it narrows back down to a standard diameter pipe has all corroded through and is barely connected at all.
Nationwide Autocentres / Halfrauds who did the test have quoted £407.
I popped into national, I couldnt remember the engine number but some of them were £100 plus and I thought mine was an ALH engine which he tapped in and came up at £600!!!
I have had a bit of the patter now about them having to be type approved after 2001 but £600!!!
I have websearched and I'm sure this is the right part and its only £110 but I dont fancy fitting it myself.
http://www.onlineautomotive.co.uk/Products.aspx?ProductID=105949&VehicleID=144056
Why are the quickfit places showing such a variation in price?
Diesels don't need a cat, so you could just have a straight section cut into the pipe to replace the cat..... Much cheaper, and the exhaust system remains legal.
Mbames speaks the truth!
You could probably get a full stainless system for 400 quid!
Plus a straight section is increase flow through the exhaust by a little bit, so may give you an extra hp or two :rofl:
Fortunately my 2001 110TDI with 187k on the clock is still going strong with its original pipe work :thumbup:
Thanks guys. What would I do to cut a straight bit in, just get some pipe slightly larger diameter and then clamp it either side with them U clamps ??
Would I just try and beg a bit of pipe from a kwik fit type place?
i looked this afternoon and the bolts to get the old bit off look in a very awkward place at the back of the engine.
Extra bhp sounds cool too - although I only do 10 miles a day in a 30 zone now !
Look around where you live, A longlife dealer near me (Oxford) cut out my cat, welded in stainless steel pipe in it's place and charged me £50 cash for everything. Just recently gone straight through an MOT also. I have a 110TDi.
Would you need to take the cat section off the car to weld a piece in or could it be done in situ?
I would imagine it would make for a better weld (and be safer) to remove the pipe and do the work off the car, but I don't have any practical experience of this.
The garage that did mine did it in situ on a car lift. Seemed to make a good job of it. Although they did use alot of equipment that I had never even seen before. Oddly shaped tools to access the tight areas and such.
Like I said it just went through an MOT without problem or even mention. It certainly isn't blowing either. But when accelerating hard the turbo noise is a bit more prominent. Most noticeably when you accelerate hard and then promptly throttle off it makes a sort of vaccum noise.
