caliper slider bolts
am i right in thinking these need changing when i do the pads?(weren't any in the box) racking my brains whether i changed a set on a leon ,but can't bloody remember :confused: :confused:
Front or rear?
oops fronts ross octy vrs :)last ones i changed came in with the pads and were blue on the end(loctite)
If you are changing the front pads then you need to undo the two 7mm allen key ended bolts behind the plastic caps. It is not common practice to change these on service.
ahh i see now.just looking on ekta,no wonder i couldn't locate what was in my head.
cheers ross much appreciated ;)
Your welcome :)
