Rear Door Making Odd Noises
Hi guys,
I've just noticed that one of my rear doors (the one on the passenger's side) has started to make a couple of noises. When opening/shutting the door, it's started making an "erk" noise when nearly fully open - I'm sure this is just a case of needing some grease spraying on the telescopic arm that's about half-way between the two hinges (as it looks like the rubber seal is rubbing against it), and nothing to cause any concern. However, it's also started making a "spring" noise (a "ping") when you shut it - any ideas what might be causing this, so I know where to look to fix it?
Both noises appeared at the same time, and I very rarely use the back doors.
Both related to check strap needing greased.
Thanks, Moggy :) (what would the forum do without you?!) :D
