Brain Unit
Hi everyone,
Is there any way to reboot, flash or reset a brain unit to factory default?
I recently bought a Skoda Octavia with the ALH engine and have been chasing my tail on trying to get the thing working. I have just been told that the brain unit might be malfunctioning so I wondered rather than replace it if It could be rebooted in some way?
Thanks,
Drew.
disconnecting the battery for half hour should reset the ECU, what problem do you actually have as that may help someone on here to help you
Every time I fix something in my Octavia 2001 1.9TDI something else happens. The car was originally not boosting properly and at around 70MPH I would get a plateau of power stopping at around 3500RPM.
Since then I have had the two pipes leading from the intercooler changed as they had had a hole drilled through them. I have now had the N75 changed and the MAF sensor and it is running worse than ever. It now has no boost at all and also rattles and clanks like an old traction engine and you can hear it coming from miles away.
There are fault codes that wont clear either which are listed below.
19561-P3105 - Intake Manifold Solenoid
17957-P1459 - Wastegate Revalve
17849-P1441 -
17552-P1144 - MAF
17660-P1252 - Timing solenoid
Two of these will clear down only to reappear the rest will not clear at all. I have now paid over £400 chasing this issue and my money is running out fast so any help is hugely appreciated.
I have just been told that there is either a fault on the ECU or a vacuum issue which they cant seem to find.
Any help is desperately needed or there will be an Octavia with all these shiny new parts up for spares or repair!!
Thanks,
Drew.
sounds to me like you need a better mechanic first off.
first place to check with lots of codes is the earth wiring down by the battery these are known to corrode and cause faults, also get someone to check that the turbo actuator is able to move freely
Could be faulty ECU, but ...
The fault codes are generated on the fly. If they are re-appearing after clearing, then problem that caused them must still be present :(
maybe its working, and just doing its job ...
Have you visited ross-tech ? [ 19561-P3105 ] [ 17957-P1459 ] ( boost leak, sensor failure ??? )
I get the impression you're using a garage, and they aren't really helping. Maybe you need a better garage :thumbup:
If you are getting 'random' errors, I would replace the ECU power relay (109) before I did anything else.
Has this been done?
Has this been done?
This has definitely not been done, where is this relay situated?
Above the pedals, under a cover.
