PD150 Turbo
If i was to get a pd150 turbo what parts are needed to run this?? do i need to change any pipes? do i need to get a front mount?
no you can use it as a direct replacement to your pd130 turbo!
all that needs done is it needs clocked (rotated)
easy peasy job, just remove bolts and rotate i believe....
a mechanic will do it no problem for you! makes sense to uprate ;)
all pipes fit its a like for like swap
you dont need an fmic, it will run at 130bhp all day long
christ back in the day my hybrid pd150 ran at 130bhp before it was mapped lol
Edited by BigJase88
lol "back in the day" lol ;)
so in your opinion its worth upgrading? what places are cheapest ive tried midlands turbos because i live in nottingham but most places will deliver anyway
well your pd130 turbo went boom did it not....
surely uprate while you have the chance to?
unless you want to replace again!
no idea but my turbo is turbo dynamics
i believe they also do a hybrid pd130 which is good for 195bhp which may suit you better as it will have quicker spool up time
is this the one i want
721021-5006S New Genuine Garrett Turbocharger GT1749V Ref: 721021-5006S
721021-5006S turbochargers fit Audi A3 TDI-150 BHP 1.9 litre, engine code ARL, year 2001 to 2004, OEM number 03G253016R, Seat Leon TDI Cupra-150 BHP 1.9 litre, engine code ARL, 2003 onwards, OEM number 03G253016R, Seat Toledo TDI Sport-150 BHP 1.9 litre, engine code ARL, 2003 onwards, OEM number 03G253016R,Volkswagen Bora TDI-150 BHP 1.9 litre, engine code ARL 2001 to 2004, OEM number 03G253016R, Volkswagen Golf TDI-150 BHP 1.9 litre, engine code ARL, 2001 to 2004, OEM part number 03G253016R. 721021- 5006S Supersedes 721021-0001,OEM number 038253016G, 721021-0004 OEM 038253016GV500, 720021-0005 OEM 038253016GV510.
Close window
Ensure it has the B on the end of the GT1749V model number, but it sounds right from the long description.
is it
038253016F
or
038253016D
also sorry about the million questions
but if i did add a fmic would i need to upgarde the clutch?
i believe its D but dont quote me on that
only if you changed the map to add more power
The turbo and maybe the odd gasketor pipe. If you specify it's for a Fabia, maybe TD or whoever will clock it for you?
Ideally, you'd get the car mapped for the bigger turbo... More fuel/boost at higher revs. At that stage, consider fitting an intercooler and a decat. Then get it mapped to suit.
The real issue is likely to be the clutch. For best performance, uprate it. Not a cheap job, however.
J.
There's about £100 in parts involved in changing over. All the gaskets and bolts add up :)
I've got the list of everything somewhere, from when I did it.
Depends what you're fitting this for - stock reliability or a good basis from which to modify?
I'm fitting as a upgrade but also with the intention of adding abit more power eventually. Ie a fmic and clutch.
Can anyone confirm whether it's the D or F on the part number above?
I have just dug out my invoice from Turbo Dynamics when I purchased my turbo.
The part number is 721021-5006S. That is the Garrett GT1749VB. That part number has superseded the previous numbers.
Also I certainly didn't buy £100 in nuts and bolts to fit it (pretty sure it came with the new bolts/gaskets etc), my mechanic just rotated the housing and on it went.
is it
038253016F
or
038253016D
Neither probably... :)
They are VW group's designations for the turbos and look older numbers than the "G" variant mentioned in your previous post. That is also superceded by 721021-5006S.
I wouldn't worry too much about the OEM numbers as long as you buy from a reputable source and tell them the model of car to which it is to be fitted.
J.
