Polo coilovers
Would a set of coilovers from a polo (1997 model year) fit a felicia?
The Felicia is based on the Favorit chassis, not the Polo, so they are unlikely to fit - at least not as a direct swap.
no. but ford mk4/5 escort will. none of the VW stuff will fit the felicia/fav suspension
you can use the front coilovers from a mk4 golf if you bore the hub carrier to 62mm
